Problems with File Dialog.vi on a Suse Linux System
we do have a problem with the LabView "File Dialog.vi" on a Suse Linux 9.0 System and LabView 7.1
The problem is that as far as we call the VI the System hangs.
What you must know is that we do have directories which contain thousands of
measurement data files.
If we remove these files the VI works fine again.
Is this a known problem?
We already tried different file systems (Reiser FS, and Extended 2)
but the problem still exists.
Is there a max. number of files which can be present on the system that this VI works fine,
or are there any restrictions concerning the length of the file names?
Should we use another File System?
Best Regrads,
Markus
(3,152 Views)
Hi Marcus,
we tried it with Suse Linux 9.2 and everything works fine. We have tried it with 4000 Files. How big are your files?
Rebecca Fox,
National Instruments, Germany
Rebecca Fox
(3,118 Views)
Hallo Rebecca,
die Verzeichnisse in denen die Files liegen sind ca. 4-5GB gross und die Anzahl der Dateien
sind ca. 1000.
Eine Umstellung auf Suse Linux 9.2 ist leider nicht möglich, da in der
Suse Version der 2.6 Kernel verwendet wird, wir aber den 2.4 Kernel aus 9.0 brauchen.
Viele Grüsse....:-)
Markus
(3,090 Views)
