Problems with Graph
I have a problem to move on a graph.
When I want to creat a new one (Copy and past) it occur a crash.
Do you know this problem and have you any solution?
What is a fpsane.cpp file?
Where is this file and can I read it?
Tank you for your attention. I hope you can help me.
Y. Goyer
(2,636 Views)
Generally an fpsane.cpp crash means that the control is corrupt.
Your best bet is to delete the graph and then drop a new one. You should then be able to copy that one and use it like any other.
What Does an "Insane Object" Error Mean and What Should I Do?
(2,609 Views)
