Problems with IMAQ Vision after upgrading from Labview 6i to Labview 6.1
We just upgraded from Labview 6i to 6.1.To do this,we uninstalled the 6i version as was suggested by NI and then installed the 6.1 version.Later when we tried to run the old vi's written using Imaq vision, we ran into different problems.Has anyone experienced any similar problems with IMaq vision after upgrading?If so please help me solve this issue.
Thanx
deepak
(2,390 Views)
What kind of problems?
I would strongly suggest that you uninstall IMAQ (all elements) and reinstall them. They register with Windows, probably docked to 6i, and also must be recompiled, which I believe is done in installation.
This is your best bet.
If you still have problems, contact NI and ni.com/ask and start a support inquiry.
(2,390 Views)
I have had many problems with IMAQ functions while upgrading to LabView 6.1. Two are very serious: I cannot build any IMAQ VIs on my NT 4.0 machine and my images come in severely cropped with the snap VIs. So far I haven't had much support on these matters from NI. I haven't had any reply from my last few e-mails.
(2,390 Views)
