Problems with ImagetoArray VI
I'm trying to read a 16 bit TIFF image to the VI "ImagetoArray" and the output seems to be an 8 bit (intensity counts from 0-250 only).
Has anyone seen this before? Also, the VI "ImagetoArray" seems to indicate support for I16 only (-32k --> +32k). How do I get it to read an unsigned 16 bit image?
I'm using the following versions of the Labview software.
Labview 7.1
IMAQ Vision: 7.1
NI-IMAQ: 3.1.3
Ivan
(3,023 Views)
Ivan,
please read your own post about I16 and U16, Lorne has already given you the answer about this: How does Labview handle 16bit images with the VI "ImagetoArray"?
One reason why the ImageToArray does not work work could be because you have connected the wrong image type to the IMAQ Create function. Have you checked this already?
BR,
ThSa
Message Edited by ThSa on 08-22-2006 07:41 AM
(3,011 Views)
