Problems with Labview RPM
I have a RedHat 7.2 system and Labview 5.1. The rpm's do not install at all. The following error message is given...
error: unpacking of archive failed on file lv51: cpio: Archive file not in header
The installation then fails. Any assistance is appreciated.
Thanks, Osei
(3,381 Views)
Osei,
Did you try manualy installing LabVIEW? This can be done in one of 2 ways - by using a shell terminal or by means of the GNOME Explorer.
By using the shell terminal
Go to directory where all the rpms are, and enter the following command:
rpm -Uvh *.rpm
You need to run the install script to install Adobe Acrobat Reader 4, the CVI run-time engine and NI-VISA.
By using the GNOME Explorer:
Right click on the RPM files and select install. NB - install the labview-rte-5*.rpm first.
There was a problem with the INSTALL script not working correctly on a Red Hat Linux 7.1 system and LabVIEW 6i. In the error that output rpm printed during the install_lv6() section of the INSTALL script, the complaint was about "/usrlocal" (no slash), not /usr/local.
There was the bug in rpm, for which last time we looked RedHat did not have a patch. This was a bug in rpm in RH 7.0 and later when using the --prefix rpm option.
Removing the --prefix option from the INSTALL script will allow the script to work successfully.
Zvezdana S.
National Instrumets
(3,381 Views)
I tried installing manually ( using shell -> rpm ) and using the gnorpm package, which is practically the same thing. I think it is a bug in the rpm given that the same error occured when using the INSTALL script and installing manually. Thanks for your assistance.
Osei (student)
(3,381 Views)
