Problems with Load DAC.flx
Hi
I am having problems to use the "Load DAC" on labview 8.2.. I am using NI7730 with a UMI 7764 and I want to put an analog value on the UMI and it always appears " Error -70022 occured at Load DAC.flx  Possible reasons: This command is not supported by this controller or operating system". Can you help me with this?
Best Regards
Ricardo Costa
(4,146 Views)
Could you provide the version of NI-Motion that you installed?
Are you sure to have a NI7730 card?
Regards
Yann C.
France
(4,119 Views)
I am sorry.
That is not a NI7730 card but a NI7330 card.. My NI-Motion is 4.6..
If it is not possible to have an analogic value on an output of the UMI is there another way? Can I use a Digital output?
Best Regards
Ricardo
(4,107 Views)
Analog output is not available on 7330 card.
Can you explain a little bit more about your project.
Regards
Yann C.
France
(4,092 Views)
I have a linear miniature actuator that needs to operate 5Vdc and I need to control its movement with labview 8.2, by changing its polarity.
To retract:   0V - 5V
To extend:  5V - 0V
http://www.firgelli.com/pdf/PQ12_datasheet.pdf
Thanks for your time..
Best Regards,
Ricardo
(4,088 Views)
Do you have a motor drive or an amplifier?
Because you can reverse the polarity by using h bridge.
Regards
Yann C.
France
(4,076 Views)
I am not sure if I understood your question..
I have the NI7330 connected to the UMI7764 and from an output of the UMI I want to have 5 Vdc. And from it I can use the H bridge like you explained..
Rafael
(4,071 Views)
