Problems with NI Softmotion
I followed the instructions on the Getting Started with NI
Softmotion manual in other to find out how solidworks can be used with
Labview. while trying to switch the Scan engine to active mode, an error
message appears as shown below.  On checking the configuration in
solidworks, i realised the option "Motion Anaylises" (Bewegungsanalyse)
is not included in the Motion study list, this seems that is the cause
of the error. How do i get rid of this error, in order to run my
simulation in Labview?
I use Solidworks 2009 SP2.1, Labview 2009fi NI Softmotion Module and NI Softmotion for Solidworks is activated.
Motion VI
Solidworks Assembly
(3,289 Views)
I saw that the you got the answer in an other forum. Is this correct?
Best regards
Rüdiger
(3,259 Views)
Yes, the Softmoiton option also has to be activated in Solidworks.
(3,248 Views)
