Problems with Parallel Port on Reboot
I use labview to drive my stepper motor connected to the parallel port
on my Win98 machine. The motor takes a step for every clock pulse sent
out on a particular pin on the port.
Although my problem is not directly related to labview, I was hoping to
get a solution. Every time I reboot my computer (at least once a day,
it seems) the computer sends a series of clock pulses to the port,
moving my motor several hundred steps. I cannot tell if it's a regular
series of pulses or just random noise.
Is there a way to disable the lpt port or otherwise prevent spurious
noise being sent out to my motor when rebooting my machine? Or when
labview is not running?
Scot
(2,928 Views)
Windows likes to check for plug-n-play devices when it boots up. You may want to set up a relay/interlock gating system that only allows pulses to reach the motor driver when one digital line is high and another other digital line is low.
-Jim
(2,928 Views)
Hi Scot,
a workaround could be a DB25 parallel port Switch Box (in the same time, you can access easier a printer using the same port). The price is around 20$.
Hope this helps ... somehow
(2,928 Views)
