Problems with Reading Signal From a Omega PX409-050G5V
Hi everyone,
I am using an Omega PX409-050G5V pressure transducer (0-50 psi) to measure the pressure of a gas tank, as gas flowing into the tank.
I power the pressure transducer with a Model T-2 Blind Power supply of 15 V (Sierra Instrument Inc.).
The transducer is connected to an NI 9219 module.
I have trouble reading the voltage signal from LabView. When I flow a gas into the tank, I don't see any increase in the pressure (or voltage). I don't know what I have done wrong.
The transducer is located at the inlet of the tank. The initial pressure of the tank is atmospheric pressure. The gas flows from a gas cylinder with pressure of 40 psig.
Could you please help me with this problem?
Message 1 of 14
(5,462 Views)
First, let's get LabVIEW out of the way. Can you read signal changes in MAX?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 14
(5,445 Views)
No, I don't  see any changes in MAX as I flow gas into the tank.
Does it mean that I have a bad connection or the pressure transducer broke?
Message 3 of 14
(5,428 Views)
Or you are looking at the wrong channel
Or it is hooked up wrong
Or the card is not working (have you done a self test?)
Mike...
LabVIEW Champion
Message 4 of 14
(5,424 Views)
I believe that I had the right channel.
I did the self test, and it was successful.
I have checked all the wires again and again, and confirmed it with one of my colleagues in my lab.
That is why I am lost as why it is not working.
Khanh
Message 5 of 14
(5,416 Views)
Hi
Have you tried to create a task and verify the Connection Diagram tab (MAX) just to double check if everything is fine? Have you tried to use another computer?
Regards
Message 6 of 14
(5,221 Views)
Yes, I did. As I hook the transducer to a gas tank, the output voltage remains zero despite the tank pressure is increasing. My guess is the transducer itself is damaged.
Message 7 of 14
(5,194 Views)
I see. Yes, could be =(
Message 8 of 14
(5,189 Views)
Exactly how do you have everything connected? Where is the common/return/ground of the power supply connected? Which pins on the 9219 are connected to what? where are the wires on the PX409 connected?
Lynn
Message 9 of 14
(5,173 Views)
The Omega 5V transducers are 3-wire devices. You supply power (12-30 V, if memory serves) on one line, there's a return line which should be connected to ground on the power supply _and_ to a ground connector on the data acquisition board, and finally a signal line which gets connected to the analog input connection.
Does this match how your wires are arranged?
Message 10 of 14
(5,160 Views)
