Problems with access to serial port using reentrant code
I have a VI that send commands and receive answers from an instrument using
de serial port.
This VI runs perfectly when used alone.
However I'm trying run two instances of that VI simultaneously using
reentrant code and I'm facing some problems.
Sometimes everything is OK but sometimes, in the process of writing to
serial port the following error happen:
Error code 36.
Invalid refnum device.
What is this?
Does someone know how to prevent this?
Thanks in advance for any help.
(3,393 Views)
Perhaps one VI is opening the port and not closing it so the other
VI can use it?
Can what you are trying to accomplish be done without reentrant
VIs?
Alan
"Paro, Paula [CMPS:2721:EXCH]" wrote in message
news:8s4uli$jii$1@nrchh45.us.nortel.com...
> Hi,
using
> de serial port.
> Error code 36.
> What is this?
> Thanks in adva
nce for any help.
(3,393 Views)
I think that the error code 36 and message "invalid device refnum"
is correct.
Have a look at the device reference numbers which are handled by
Open Serial Driver.vi. I don't actually know what you have done,
but make sure that the Open Serial Driver.vi is not reentrant.
Martin
Martin Henz Systemtechnik
Dipl. Ing. (FH) Martin Henz
Walchensee Str. 3
70378 Stuttgart
Tel. ++49-711-5302605
Fax ++49-711-5058649
http://www.mhst.de
"Paro, Paula [CMPS:2721:EXCH]" schrieb im Newsbeitrag
> Hi,
> de serial port.
> Error code 36.
> What is this?
(3,393 Views)
"Paro, Paula [CMPS:2721:EXCH]" wrote:
> Hi,
> de serial port.
> Error code 36.
> What is this?
You can't use reentrant vi's vith serial vi calls without supervising of
driver.
Use VISA instead and you have to control the VISA session opening and
closing. Another word is that the only one serial port sess
ion should be
opened at a time.
Reentrant vi's for serial port without checking serial port session is a
mistake of program algorithm. Change it in any convenient way.
Sergey Krasnishov
____________________________________
Automated Control Systems
National Instruments Alliance Member
Moscow, Russia
sergey_acs@levsha.ru
http://acs.levsha.ru
(3,393 Views)
