Problems with application builder
I have a little problem to distribute my application.
When you install the program, a direct link to the program appears in Start
Button, but not the link with the "uninstall" program. To uninstall the
program is neccesary to go to Start->Settings->Control Panel->Add/Remove
programs, but this is a little inconvenient for a not-advanced user.
Thanks in advance,
Miguel.
(2,850 Views)
This is where I would expect to see uninstall. All of MS Office, LabVIEW,
CVI, Acrobat, AutoCad, Visio, Internet Explorer, Visual Basic, etc., etc.,
are all uninstalled from the Add/Remove Programs. I think having uninstall
as a shortcut from the Start menu is a little dangerous as it's too easy
to select.
"Miguel" wrote:
>Hi,>>I have a little problem to distribute my application.>>When you install
the program, a direct link to the program appears in Start>Button, but not
the link with the "uninstall" program. To uninstall the>program is neccesary
to go to Start->Settings->Control Panel->Add/Remove>programs, but this is
a little inconvenient for a not-advanced user.>>Thanks in advance,>>Miguel.>>
(2,850 Views)
