Problems with arduino labview Interface
@VitorMota wrote:
Hello!!
Im having the same issue. What did you do to solve the problem?
Thank you for your help!!
Can you be a lot more specific about your issue, preferably in a new thread?
Message 11 of 15
(1,184 Views)
how you have solved??
Message 12 of 15
(1,167 Views)
My problem is there is an error warning in lifa base compiling. how it can be fix????
C:\Program Files\National Instruments\LabVIEW 2013\vi.lib\LabVIEW Interface for Arduino\Firmware\LIFA_Base\LabVIEWInterface.ino: In function 'void processCommand(unsigned char*)':
C:\Program Files\National Instruments\LabVIEW 2013\vi.lib\LabVIEW Interface for Arduino\Firmware\LIFA_Base\LabVIEWInterface.ino:150:60: warning: left shift count >= width of type
duration=(command[8]+ (command[7]<<8)+ (command[6]<<16)+(command[5]<<24));
C:\Program Files\National Instruments\LabVIEW 2013\vi.lib\LabVIEW Interface for Arduino\Firmware\LIFA_Base\LabVIEWInterface.ino:150:77: warning: left shift count >= width of type
C:\Program Files\National Instruments\LabVIEW 2013\vi.lib\LabVIEW Interface for Arduino\Firmware\LIFA_Base\LabVIEWInterface.ino: In function 'sevenSegment_Config(unsigned char*)':
C:\Program Files\National Instruments\LabVIEW 2013\vi.lib\LabVIEW Interface for Arduino\Firmware\LIFA_Base\LabVIEWInterface.ino:632:41: warning: iteration 7 invokes undefined behavior [-Waggressive-loop-optimizations]
sevenSegmentPins[(i-1)] = command[i];
C:\Program Files\National Instruments\LabVIEW 2013\vi.lib\LabVIEW Interface for Arduino\Firmware\LIFA_Base\LabVIEWInterface.ino:629:3: note: containing loop
for(int i=2; i<10; i++)
C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\main.cpp: In function 'main':
Sketch uses 18,070 bytes (56%) of program storage space. Maximum is 32,256 bytes.
Global variables use 1,116 bytes (54%) of dynamic memory, leaving 932 bytes for local variables. Maximum is 2,048 bytes.
Message 13 of 15
(1,157 Views)
Is there a reason why you are still using LIFA? Its been replaced by LINX.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kJ7DSAU
As far as the LIFA error is concerned, take a look at the following article and make sure that its setup correctly.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8ilSAC
Message 14 of 15
(1,126 Views)
Pude solucionarlo desinstalado el arduino 1.8.2 y le puse un arduino 1.6.0.
El cual al cargar la Interface me marco un par de error en librería (register-root) la cual elimine. Saludos
Message 15 of 15
(1,103 Views)
