Problems with automations in stand alone executables
We have an application the uses an automation developed in visual c++ to establish communication with a PLC, it works perfectly in Labview, but when we built an stand alone executable it doesn´t work fine.
The automation uses a type library (*.tlb), we registred it in windows, but it doesn´t work.
What can we do?
You can find attached the vi sorce code for the stand alone executable.
Thank you very much for your help.
(2,844 Views)
What error do you get?
You should install and register your activex objects or .tlb's on both development and target machines.
Zvezdana S.
(2,844 Views)
My bad was that I registered the .tlb only on the target machine.
I just registered the .tlb on the development machine then compiled it and the application works fine.
(2,844 Views)
