Problems with dynamic Datas under Windows XP?
Hi
I have the problem that my Application stops, after an indefinite time, with an Windows error
could it be that there is a problem with the dynamic data under Windows XP?
i have atteched my Application and the erromessage from Windows.
(2,804 Views)
Hallo,
the first thing you should try is, add a timing to your second while loop (beneath the 'main' loop >> check task-manager for CPU efficiency). maybe this already solves the problem.
Daniel Riedelbauch
(2,773 Views)
