hello,
i'm using the scope tds 6604 with tektronix
lv-driver (TKTDS6K) under lv 6.0.2.
I always want to read the displayed waveform via GPIB.
This is not a problem. The waveform and the scales are correct. BUT if I stop the aquisition on the scope
Run/Stop-Button) and then change the time- or
amplitude-scale or the position of the graph on the scope, I read the correct waveform but the scales are incorrect. I tested it for a while but I could not see a system. Perhaps do I have to use some mathematical operations with the array, in order to receive again the correct scalings and positions?
thanks in advance, sven
