Problems with mass compiling for LabVIEW 6.0.2
When mass compiling the LabVIEW folder after installing 6.0.2, I get a Log file telling me "Bad VI" for 8866 vi:s. Have looked specifically at two of them, and the broken arrows are fixed by pressing and clicking the broken arrow. Somehow I don't feel like doing this for 8866 vi:s.
What is wrong, and how do I fix it?
Attaching the Log.
//Martin
(2,872 Views)
Try de-isntalling and re-installing NI-DAQ.
All of the errors seem related to DAQ.
Ben
(2,872 Views)
Yes, it definitely appears as though you need to reinstall NI-DAQ. You can receive this error when the VIs which are being mass compiled depend upon other VIs which are either not present or have been incorrectly updated. Make sure that you have installed NI-DAQ support for your new version of LabVIEW. This is separate from installed NI-DAQ by itself. You must install the LabVIEW support files also. You can get these off of NI's website.
J.R. Allen
(2,872 Views)
Also, if you did a complete install of LabVIEW, you may have installed a newer version of NI-DAQ without realizing it. This could cause a problem if there are two versions of NI-DAQ on your computer. Make sure you only have one version.
J.R. Allen
(2,872 Views)
