Problems with mediaplayer ActiveX
I tried to use the MS Mediaplayer to play an avi file!
To do so I used the AciveX control! It plays the videos just fine but somtimes it leaves image fragments of the player container behind! I dont know what kind of error this is! it doesn't happen everytime!
I'm posting the vi below so you may see what i did wrong!
I'm thankfull for any help!!
(2,951 Views)
On my computer works properly (even though I noticed the same effect after using Media Player in other situations not related to LV - check on MS site, maybe is their problem).
Anyway, as far as I know you shouldn't use Open and Close Reference in this case ("How Does ActiveX Server Automation Differ from ActiveX Controls?"-[http://digital.ni.com/public.nsf/websearch/53BAD0DF6128E846862568E7006E2DF7?opendocument&Submitted])
Hope this helps ... somehow
(2,951 Views)
at the very end of the reference calls, just before close the reference or exit the program, create an extra reference node that opens a avi file, but now, just wire empty string to it. i hope this works.
joe
(2,951 Views)
