Problems with opening file with while loop
Hey Greg,
  Much clearer now. I really appreciate the response!
  Thanks!
   TheLT
Message 21 of 23
(961 Views)
@johnsold wrote:
Greg,
There definitely is a point where it becomes necessary to read in chunks.  I recently was processing text-based spreadsheet files of >100MB and having both string and numeric arrays in memory at the same time created memory problems.  By reading in chunks I was able to get the memory footprint to a few percent above the final numeric array size.
Lynn
Lynn,
We should chat! I recently did the same thing, hundreds of rows by hundreds of columns in CSV files. Luckily the computer was able to handle it all in memory at once, but I was really pushing the boundaries. If they expand the data to include additional columns, we may need to refactor. Unfortunately I was under a time crunch, and because there was enough memory and generally the files shouldn't change much, I had to take the quick way out.
Message 22 of 23
(942 Views)
Greg,
PM sent.
Lynn
Message 23 of 23
(932 Views)
