Problems with resampling an unequally sampled signal
Hi there,
I am having some issues with resampling an unequally sampled signal.  The TSA Resampling vi (unequal) seems to work on some signals but on others there are major peaks and valleys that appear in the resampled signal that make it unusable. I was just wondering if anyone has any insights on what may be the limitations of this vi and if there are any alternate solutions.
I am attaching an example of the 3 channel files I am dealing with that I put into the LV example resampling vi.
Thanks so much for any help you can provide!
(4,532 Views)
PA_UW,
This question may be a bit too specific for LabVIEW forums. You might have better luck in the Signal Conditioning forums.
Signal Conditioning
http://forums.ni.com/t5/Signal-Conditioning/bd-p/300
Otherwise, you can email filter.support@ni.com for specific help with the advanced filters.
Austin
Staff Software Engineer
NI
(4,494 Views)
Thank-you for your suggestions - I appreciate them and will give them a try.
(4,492 Views)
