Problems with the DAQCard 1200 and waveform
every time I try to aquisite Data with AI Acqire Waveform I get a time out error. And when I use the AI Read there is the same Problem!
May someon can tell me if it's my fault or it is a general Problem of the 1200 Series.
(2,744 Views)
Here are a few things I can think to try:
1. Run a simple example like Acquire N Scans.vi? It should run on that board with the default settings of the VI.
2. Reduce your sample rate. While that device can acquire at 100 kS/s, your laptop might not be able to read the data off the board that fast.
Doug
(2,744 Views)
