Problems with traditional NI-Daq after upgrade
Sorry, I though the fact that I replied that I have reset the drivers would imply that the device is present in MAX. I do have the traditional drivers installed as well. The device is visible under both the traditional drivers as well as DAQmx. I could post the entire VI, but I don't think I need any more of your snark. Thanks for the advice about find and replace. I'll see what I can do with that.
Message 11 of 13
(627 Views)
Hi tavis,
Cool off guys, we are trying to help you solve the problem here. I was looking at your VI, however, I could not help further if you do not provide us with these VIs:
1. Fuel SP global.vi
2. Current Fuel SP Global.vi
I opened your VI and it prompted me with missing VIs, which I mentioned above. If only you provide us with that, I will be able to help you further!
Have a nice weekend!
Sincerely,
Krisna Wisnu
Certified LabVIEW Developer (CLD)
Certified TestStand Developer (CTD)
Using LabVIEW 8.5.1 (2008) to LabVIEW 2024
Message 12 of 13
(613 Views)
And I was simply asking for confirmation whether he's resetting the device correctly. If traditional DAQ is active, then the test screen under the tradtional DAQ will work and that will confirm that not only is traditional DAQ is installed correctly but is active. I happen think that is a pretty fundamental step in trying to determine what the exact problem is.
Message 13 of 13
(600 Views)
