Problems with vision authentication when built in Labview 2023 Q3
I am using 2023 Q3 labview
I tried to build it and use it as an exe file, but it said I needed to authenticate the license below.
But I want to use it without authentication. Is there a solution??
Does vision have to be authenticated even if it is built??
I am using the paid version. There should be no problem in building, but there is a problem using the exe file on another PC after building.
(2,212 Views)
Accepted by topic author RongTime
When using the Ni-Vision module in a application, you need to have a run-time License for the PC that will run the application.
What you pained for is the development version of NI-Vision.
(2,185 Views)
Licensing NI Vision Software
https://tmesystems.net/
(2,152 Views)
I am foolish for not installing the NI package module and asking such a question. Thanks to the great two heroes
(2,143 Views)
