Processing Strings
I have a string (a filename) of length x characters. I wish to delete the last n characters from the string.
x > n.
n is a known constant.
x is unknown.
I have an idea how I would perform this with an array, but I'm not sure how I perform this on a simple string.
(I actually have to perform this on multiple strings in a 1D array of strings, but I plan to use a for loop when I know what code I need to use.)
Can anyone advise me on where to start manipulating this problem please.
example:
132124_536_YYMMDD_HH;MM;SS.doc = string for processing
132124_536 = desired result
_YYMMDD_HH;MM;SS.doc = string of constant length but changing contents
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
(3,052 Views)
Accepted by topic author James_W
Hi James W,
you can use the "String Subset" function. Connect "length(string) - n" to the length connector.
Mike
(3,051 Views)
Ahh. Thanks Mike
(3,047 Views)
