Processor maxed out when starting RT application in development mode.
When I go to run my RT application on my 8145RT board in development mode, one of my dual-core processors stays maxed out for 2 or 3 minutes.  I added a break-point at the very begining of the code to make sure it was not something related to the execution of my code.  This only happens if I make a change to the code and have to re-download it.
I am using LabVIEW 2009.
Any ideas?
(3,253 Views)
Does the application respond normally once it is compiled and downloaded as rtexe?
Christian
(3,234 Views)
Yes, as a built .rtexe it behaves normally.  There is no delay.  Also, if I stop the application (in development mode) and restart it without any changes it behaves normally.
(3,191 Views)
I know this behaviour and I think (but I'm not sure) its a bug which is allready reported. Right now I'm out of office and cannot access the DB to check the CARs number, but as soon as I'm back I will check and update you here.
Christian
(3,185 Views)
