Produce second pulse from latch button press
I would like to generate a second latch pulse from a single press of a latching Boolean type button.
I currently have two buttons - the user presses the first (it performs a "reset" type operation) then presses the second button (for a "capture"). A reset must be performed before the capture, and my code is written so that both work with Latch When Pressed mechanical action.
I have tried using Switch When Pressed mech action and performing eg. Reset on True and Capture on False, but this doesn't work for other reasons within the code.
What I would like is for one press of a single button to generate two pulses: a first pulse I can connect to the "reset" piece of code, then a short delay, and then a second pulse I can connect to the "capture" piece of code.
thanks,
Kathryn
(4,501 Views)
What is this pulse?  Is it something you want to send out of a DAQ device?  Then just create a waveform that has both pulses with the desired delay, then when you press the boolean button, have it output the waveform from the True case of a case structure.
(4,499 Views)
Hi RavensFan,
Sorry I wasn't specific enough. No, the "pulse" I was referring to was the term I'd chosen to represent the False-True-False Latch mechanical behaviour of the Boolean button. It/they are not being sent to a DAQ device.
I would like one button press to operate as two: to generate two Latch type "pulses" with the first "pulse" to go to the selector terminal of one Case structure, and the  second "pulse" to go to the selector terminal of a second Case structure.
thanks,
Kathryn
(4,491 Views)
Hi RavensFan and other forum members,
I'm sorry if this thread is a stupid question, and I hope I was clearer in my second post. I dont' feel I can use a Waveform for the selector of a case statement, I created a waveform in the shape of a pulse, and did a "greater than" comparison with the magnitude of the waveform I created but this creates a Boolean array, which I don't think will work for the case statement selector. If I am wrong here, can you please give more detail as to how I can use a waveform to create two Boolean pulses to use for two separate case statement selectors.
I am looking at two options, either will work:
1. Using a switch in Latch When Pressed mode, two Boolean pulses are created, one after the other with a time gap, for the selector of two separate Case statements.
2. Using a switch in Switch When Pressed mode, one pulse is created on a rising edge and a second on a falling edge. In this case, the problem may be how to create a Boolean pulse from a step change in sense.
The Boolean signals have to be F-T-F pulses rather than held True.
 Any help appreciated...
thanks,
Kathryn
(4,457 Views)
Try this.  The switch is set to latching.   It will blip an indicator on when first pressed.  It will blip a 2nd LED on 3 seconds later.  One problem is that the elapsed time VI automatically resets itself on first call.  I believe if you convert that to a subVI (right click, Open Front Panel) and go in and remove the First Call? primitive, it will prevent that from happening.
Message Edited by Ravens Fan on 02-17-2010 03:01 PM
(4,446 Views)
