Producer/consumer architecture timing error
       I am using Producer/Consumer architecture for acquiring strain measurements using multiple channels. Also, I am interested in writing data every 1 minute since the program has to be run for a month. Currently, I am getting an error 200279 whenever I increase the timing from 10 sec. To control the execution of producer loop, I am using  "weight until next ms multiple" function. According to error message, I tried to fix the samples to be read without increasing the frequency of data acquisition, but I am still getting the same error.
Piyush
(3,655 Views)
It doesn't sound like the problem is due to your producer/consumer architecture, but to your DAQmx functions.
10 seconds is a long time between DAQmx reads.  You'd probably be getting a timeout error unless you happened to increase the timeout function.  Your DAQ task creates a finite size buffer that probably isn't long enough to acquire more than 10 seconds worth of data.
You need to either increase the size of your buffer, or set your acquisition to occur more frequently.  If you are using a Wait until Next ms Multiple inside of a loop, a 10 second wait in there is a rather long time.  It would probably cause your program to feel unresponsive if you hit the stop button.
(3,643 Views)
Of course posting your code would help so we do not have to guess.
Tim
GHSP
(3,635 Views)
Here is the code.
Piyush
(3,631 Views)
There are missing a sub vi from your code.
The code don't show how you configure the DAQ. That is an importen point.
Othervise, be carefull with overlapping elements like wires and functions. You have a lot of those.
And why are you using the Lossy Enqueue Element for putting an element in the queue?
You have a unlimited size queue, no need for lossy enqueue.
(3,624 Views)
Accepted by topic author PChauns
Your test3.vi wasn't included so we don't know what is going on in there.
What is the acquisition rate for your DAQ task?  What DAQ device are you using?
Have you tried increasing the size of the buffer?  There is a property node that can set that.
(3,623 Views)
Thanks for your help. The issue is resolved now by increasing the buffer size.
Piyush
(3,608 Views)
