Product evaluation problem
    Actually I am using teststand 2014 under evaluation period and on top of that I installed labview 2017.Now the problem is that even there are some evaluating days left for teststand
it can't be run as it is prompting me to activate the product and LabView is running.
But later on I came to know the lifecycle of labview 2017 is not supported with teststand 2014.
Are there any other solutions so that I can use both at a time under evaluation mode on same system.
(2,888 Views)
I can't answer you regarding the issue with evaluation mode; but if NI clams, that LabVIEW 2017 is not compatible with TestStand 2014, there's not so much to do with it; you can't workaround this. Try to install TestStand 2016 - I guess it'll be compatible with LabVIEW 2017.
(2,860 Views)
