Profinet Card from NI
Since NI do not offer a PCI based Profinet card, I used a card from Comsoft which I procured in 2015.  At that time I had used this card to interface with a Beckhoff EP9300 gateway module to convert the Profinet bus to EtherCAT bus modules.
Now the customer is moving to Siemens Profinet I/O Modules dropping the EtherCAT  modules. I guess I can continue with the Comsoft PCI card itself. Or is there any other better option to interface the Siemens Profinet bus with LabVIEW 2017 ?
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
(3,717 Views)
Can you use the following two NI products?
http://www.ni.com/en-us/shop/select/c-series-profinet-interface-module
http://www.ni.com/en-us/shop/select/pxi-profinet-interface-module
(3,676 Views)
