Progmatically Changing Visible X Scale Range of Waveform Chart
Hey All,
How can I progmatically change the visible area of the x-scale on a Waveform Chart?
I want to be able to say enter in a number, like 50 and see the display update to display 0-50, however, once it hits 50 I want it to either update based on Sweep Chart settings, Scope Chart etc...
I can set the scope of the x-scale, like 0-50 using the x-scale range min and max property nodes, but it doesn't update continuously. And I also don't like the way you can do it using the graph palette property. Although this is the functionality I would like to mimic.
Any ideas?
Brad
(2,997 Views)
Hey Brad,
Is this what you had in mind?
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(2,979 Views)
Yes, thanks for your help I figured out what I was doing wrong in the process.
Brad
(2,946 Views)
