Program Labview on PROFINET
Hello I am new on LABVIEW and I would like to have the help of the community
I explain you the context I have to drive a cylinder on a test bench through a PROFINET of the brand KUNBUS this card is on a chassis PX Ie-1073 and the card is connected via an internet cable on a PARKER compax3 Fluid
After following the instructions recommended by KUNBUS I am blocked at the creation of the authorization of a new server, I wanted to continue and with the software KUNBUS configuration 3, I manage to create a configuration as stipulated on the PDF
Then I wanted to try to program the card on Lab VIEW, I wanted to try DAQ assistant but I do not find my card in the inputs and outputs, my question is: DAQ assistant allows to drive the profinet? or as I did not create authorization of the server that I am blocked
it is possible to have examples of programming of the PROFINET
Translated with www.DeepL.com/Translator (free version)
(1,757 Views)
Hi Bassem,
DAQAssistent is only used to handle DAQmx devices from NI, it will not handle any other devices.
You need to use the driver for your Kunbus device as should be written in the manual of that device!
(AFAIK NI is no longer selling Kunbus devices so you need to ask Kunbus support directly.)
(1,751 Views)
