Program crash after 30 minutes runing !!
You could use ModBus but it's an other adventure but if you have to provide your software soon...
Message 11 of 13
(1,732 Views)
I can confirm that the iTools OPC Server will only operate for 30 minutes, with third-party OPC clients such as LabView, unless a Product Key is purchased from Eurotherm.
Regards
Mike
Message 12 of 13
(1,705 Views)
I concur with Mike.
The iTools OPC Server will only operate for 30 minutes, with third-party OPC clients such as LabView, unless a Product Key is purchased from Eurotherm.
This is clearly stated in the iTools Demo page http://www.eurotherm.com.au/itools/itools.htm here is the extract “….. will run for 30 minutes for evaluation purposes. After this time a product key is required to permanently enable…..”
Message 13 of 13
(1,651 Views)
