Program driven legend min/max
Hey guys,
I wrote a VI to create circular sample patterns for an autosampler, and would like to output the sample locations in an XY plot. I like autoscale because the sample patterns will vary in size, but I was wondering if anyone had a suggestion about how to make the legends grow to the same value. I'd like the aspect ratio to be 1:1 basically.
As an alternative, I thought that I might be able to just use set values as opposed to autoscale, but have these values be driven by a case structure (or set of case structures) that directs the values into an XY plot with appropriately sized legends.
Let me know if you have any suggestions,
Thanks!
(3,131 Views)
A picture is worth 1000 words, and a VI is worth 10,000 words.
Hard to understand what you are talking about without seeing either.
(3,123 Views)
Hello Mark,
I see that you are generating a circular pattern on a XY plot. For this I would recommend using the property nodes available on the indicator such as Fit Scale and such as it is shown on the image attached.
I would be very helphulf if you could get a snippet or a sceen capture of your code to exemplify the situations that you are explaining. But I will definitely give it a try with case structures.
David Melendez
(3,086 Views)
