Program for CompactDAC USB 2.0 chassis and NI 9211 4-CH Thermocouple input module.
Does somebody have and easy Labview program, that i create an array whit only my measurement data.
At the moment I create a complex array with a time and date stamp and also the measurement data.
This complex array is not easy to work with.
Is there an easier DAQ assistend module then that I have at the moment.
Tanks for your help.
Dries
(2,721 Views)
Hi Beyens,
It will be maybe better if you say which version of LabVIEW you are working with. And maybe send a little example of your code or your code self.
Julien Roland - District Sales Manager
NI Belgium - Technical Support
Don't forget to rate a good answer
(2,700 Views)
