Program freezes on startup, sort of
This has happened to me a couple of times, but hasn't been an issue until now.  I have written a new application (Labview 7.1) and for some reason, sometimes it acts "frozen" at startup, like something isn't being initialized.  I have a set of tabs and there is a button on the first tab to "advance" to the next tab (using an event structure to detect when the button is pressed).  For some reason, especially after I build the program and run it as an exe, I have to press stop and then run before it will recognize the button click.
Anyone else have this problem?  Any suggestions?
(3,660 Views)
can you post your vi/code?  i will attempt to help you if i can see it :)
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(3,631 Views)
I think I may have fixed it, although I'm not certain what was causing it in the first place.  I believe it had to do with having multiple event structures, although I don't know how any would actually affect each other, and why it would freeze on startup.  I replaced the first 2 event structures with while loops and just handled the events myself, and it runs just fine.  Thanks for the reply though.
(3,629 Views)
Go to the LabVIEW help and read the caveats section under Event structures. Multiple event structures are usually not necessary and can cause the lockup problem you saw.
(3,624 Views)
yes, dennis is right - multiple event structures should be avoided and can demonstrate this behaviour.
(3,617 Views)
Thanks for the help.  I guess I had seen that, but didn't think the way I was using them would interfere with each other.  The program works just as well without the other 2, I was just trying to be consistant.
(3,611 Views)
