Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Program hangs at While loop breakpoint while stepping
LBieber
Member
07-30-2002
04:13 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I have a breakpoint set on a While loop. I run the program and it stops at the breakpoint. I set up some probes and continue to run through the loop. After several iterations the program will not respond to further run commands.
0
Kudos
Message
1
of 2
(2,954 Views)
Reply
Re: Program hangs at While loop breakpoint while stepping
Ben
Knight of NI
07-30-2002
05:58 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
This sounds incredbly bizarre.
Could you post this code for us to look at?
I have seen one strange thing using the debugging tools and this is not it.
Ben
Retired Senior Automation Systems Architect with
Data Science Automation
LabVIEW Champion
Knight of NI
and
Prepper
LinkedIn Profile
YouTube Channel
0
Kudos
Message
2
of 2
(2,954 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
