Program to turn on the LED when motion is detected by setting 3 areas
https://forums.ni.com/t5/Example-Code/Motion-Detection-Using-NI-Vision/ta-p/3532423
AAdoordoorbb
A Chamber: Door: B-chamber
After dividing into 3 areas and setting the ROI
I want the LED to turn on when motion is detected.
There are many examples of ROI setting, but I am going to upload it here because it is too cramped and going crazy. ... I used My Labview, but this is my first time .. Please ... I think it would be a hope if someone could answer me. Hyo .. Thank you.
(1,865 Views)
HI,
What is your problem ? This is way too vague, we can't help you without more information. What have you tried so far ? Can you post your code (in a ZIP file if there are several files).
Yddet
(1,823 Views)
