Program won't build if a broken vi is included in a diagram disable structure
I develop code that can run on both PXI and Compact RIO devices.
To allow for the different DAq methods I have a target specific child object that I tried putting in a conditional disable diagram.
I found that even if it was disable, the build would still fail.
When you build rio code on a pxi target, you et problems But I didn't expect them if the class was diagram disabled
In fact it won't build if it is in the project at all.
Posted as a bitter lesson for others to avoid.
iTm - Senior Systems Engineer
uses: LABVIEW 2012 SP1 x86 on Windows 7 x64. cFP, cRIO, PXI-RT
Message 1 of 1
(2,212 Views)
