Programatically Change Tab Control Image
Is it possible to change the tab image of a tab control using program calls?  I can add an image to a tab by right clicking the tab, then selecting Advanced --> Tab Layout --> Import Image From Clipboard.  This works well when editing the VI, but I would like to change the image while the VI is running.  Any help?
I have found no resources online, or by looking at the property node or invoke node for the tab control.
(2,764 Views)
Not possible. The image can only be set while in edit mode.
(2,751 Views)
