Programatically Create GUI ?
Here's my XControl example:
Ton
Message Edited by TonP on 06-20-2007 08:28 AM
My LabVIEW Ideas
Message 11 of 17
(2,951 Views)
I'm a bit late in this thread, but would like to throw in my two cents worth.
I think, TonPs solution using XControls is very exciting, making it easy to build up an array of references to XControls and changing the appearance via property nodes. But I have no experiences with this, so I can only offer a solution in the more "generic" way.
The hint of Jarrod brought me to the better second way, not to use pictures than to make snapshots of real controls. Take a look at this example, I think it behaves quite "natural".
greets, Dave
Message Edited by daveTW on 06-22-2007 11:21 AM
Greets, Dave
Message 12 of 17
(2,900 Views)
Hi all,
   Sorry for the later reply. here is an example of the interface we are creating now.  We need to interact with all the controls and each time one is changed an event will be triggered (pretty much a serial bus write with the data being send to the subVI dependant on the control that was changed),  each tab contains a similar map.
Based on the replies to this thread I've seen how the scripting tools can help me generate numerous controls programatically, but I'm at a bit of a loss on how to link these new controls to the input of the sub VI that performs the write.  Normally local variables are used in my application.
Message 13 of 17
(2,884 Views)
Ok, I think I see. You have this display that mirrors the memory map for some device that you are testing/programming. When run, the operator manipulates the various various controls associated with each memory location in the target device, and then has the option of saving those changes. I assume that the other tabs have the same basic task, but differ in the specifics of the memory map that is displayed.
To start, consider that the possible combination of controls is actually rather limited, if you think about it: You can have up to 8 bit buttons and 4 popup controls (since you are using popups for values that are encoded in two or more bits) - or some combination of buttons and popups. So all the variability you really need for each memory location is the ability to make 8 bit controls appear or disappear, and the ability to change the visibility, position, width and strings of 4 popups. In addition for all 12 objects you need to be able to set their captions. The idea is that for a given memory map the code would control those 12 elements to make each row different, when it is actually the same cluster datatype that you are making appear different by manipulating the property node associate with each of the 12 items in the cluster. This cluster should be a typedef.
Given that there are 10 memory locations on the page, you will need 10 of these clusters. So to simplify the processing you want to place those 10 independent clusters into a single cluster. The result is that the top-level data structure for the display will be a single cluster containing 10 copies of the typedef'd cluster.
Now to allow your code to manipulate this display, you first need two arrays: One contains the description of how each typedef'd cluster should appear, defined in terms of the things listed above. The second array holds the data that each typedef'd cluster contains. These are maintained separately because the  cluster definitions are only changed when the target memory locations being edited are changed, where as the data changes as the user manipulates the various controls to change the contents of each memory location.
In terms of code (and I am assuming an event-driven interface here) you will need, to begin with, an event for initializing the display. This event includes a subVI for reading the cluster descriptions from wherever you decide to store them; a subVI for initializing the appearance of the display; a subVI for reading the data to be display (presumably from the target device); and a function to fire the display update user event described below.
Next, a display update user event will contain subVIs that take in a reference to the top level cluster, the array of descriptions and the array of data and updates the display to show the data.
Finally, a third event (a value change event on the top-level cluster) contains code that using the NewVal and OldVal event data determines what value the user has changed, updates the data array to reflect that change and fires the display update user event.
You might also be able to meet this requirement using X-controls, but years of beating my head against walls has taught me to not implement new features too soon. For example,ActiveX controls were introduced in LV V5 but it took a couple revs of LV to get them to the point where the kinks were worked-out enough for them to be usable in a deployed application. You don't want to structure your code based on some new capability only to find out that you are pushing it beyond what NI had tested and it contains bugs that prevent it from doing what you want to do.
In any case, the point of this post is to outline the approach I would use to address this design challenge. To demonstrate that this really does work, the example at this link shows the interface to an application that I created using the basic technique I have described here. It implements a scrolling list that appears to have different data in each element. Extract the contents of the archive into a folder and run the VI ~Interface Test.vi.
I understand that this is probably a much larger answer than what you were looking for, but this is a complex interface that you want to create. However, if you decide to go forward with this you will learn a lot about how LV works and how to design an application. If this sounds interesting let me know and we can start stepping through the design/implementation process...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 14 of 17
(2,863 Views)
Mike, that is impressive. I will have to examine that when I have more time.
___________________
Try to take over the world!
Message 15 of 17
(2,850 Views)
OK, Mike, I finally had time to look at it and it takes a while to figure out what's going on, but that is really very impressive. I might "borrow" some of that code if I ever need something like it.
I would probably make some changes (maybe avoid the binary save and try to encapsulate as much as possible into subVIs), but even like this this provides some interesting ideas and a nice interface.
___________________
Message 16 of 17
(2,720 Views)
Feel free to use what you can! Especially take the concepts - they're what's really important anyway.
What you said about the binary saves is good. I don't remember of I mentioned it but this is a stripped-down screen from an application I developed. The original version used databases to hold the setup information - as well as the results of the editing.
Mike...
LabVIEW Champion
Message 17 of 17
(2,713 Views)
