Programatically Link Tables wiith SQL
Is there a way to programatically link tables from one Access Database
to another using SQL?
Thanks!
Tim Erickson
(2,872 Views)
I can't give you a definite answer, but a direction to start looking would be to check the MS website and see if you can find an example of how to do it either using ActiveX or a combination of ActiveX and a macro. If you can find such an example, all you have to do is recast the calls to LV-style ActiveX operations. Alternately you may find that such remote operation is not possible--in which case you have your answer.
In any case, please keep the list posted with what you find as I sometimes get stuck using Access and the information could be helpful.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,872 Views)
