Programatically Replace with Item Found by Project
I have a Support folder that is Auto-Populating. I need to rename this for example to SupportFiles. This folder contains 1000+ VIs and ctls.
As expected, when I do the rename of the folder in Windows it causes conflict in my project.
Ideally, I can use the Replace with Item Found by Project to resolve this. But, I don't want to do this manually for all the 1000+ VIs.
Resolving Project Conflicts - NI
I am looking for a scripting VI that implements this Replace with Item Found by Project. Something similar to the one below:
Programmatically replace a project item? - NI Community
(969 Views)
Hi Jamison,
Do not move the VIs externally, go instead to the Files view (accessible from your project window), then select the VIs you want to move, right-click > "Move on Disk..." > select the new folder (existing or create a new one), "Save All" when prompted. Then go back to your Items view, do a "Stop auto-populating" on your Support Folder, then again "Convert to Auto-populating Folder..." again and select the new folder.
Raphaël.
(913 Views)
Hi Raphaël,
I have already tried that method, as mentioned from these two KBs:
Moving VIs in a LabVIEW Project to a Different Folder - NI
Renaming Auto-Populating Folders - NI
The problem with this approach is, as soon as you Move Files on Disk and selecting the folder. It adds the files again which results to having conflicts.
I am not sure if there is some steps that I am missing. But this method does not work for me.
Therefore, I was trying if there is a way to this scripting from the project level.
(903 Views)
What if you first make the auto-populating folder a normal virtual folder (Right-Click -> Stop auto-populating)?
(899 Views)
