Programatically advance Scroll bar in Listbox
Scrollbar has many multiple lines in it. Only one item at a time is
programatically selected during a repetitive process. I need to make
the scroll bar move to allow the selected item to always be at center
or is there a better way? As it is now the selected item will go below
the visible range as the loop increments and I cannt make the scroll
bar move programatically.
I am missing something simple I hope.
PS: LV-6.1
Thanks in advance
(2,918 Views)
Use the property node "Top Row", this will make the input row to be
the first visible row.
Joe
(2,918 Views)
Thank you Joe Guo
Works like a charm.
(2,918 Views)
