Programatically change plot names in mixed graph chart
Have the following mixed graph chart in my VI:
All my signal are visible and good when I run the VI.
What I would like to do now, is to be able to dynamically update the names of the individual signals as well as be able to select which signals are visible.
I have seen the property node 'plot-> visible' but its does not appear to works on individual signals.
Any suggestions on how to implement the above scheme would be much appeciated
(3,709 Views)
Accepted by topic author sherzaad
You also need to use the property node Active Plot to set which plot you will be acting on.  This can be done in the same property node, just make sure it is above the properties where you set the visibility and name.
PS:  It is either a graph or a chart, it can't be a "graph chart".  They are important differences between the two terms.  Graphs do not contain a history, charts do.
(3,697 Views)
Thanks! just what I need to know!
(3,618 Views)
