Programatically changing the sizes of multiple front panel objects
What I would like to do is be able to take an object on the front panel and somehow change its size programatically (not by using the selector tool and manually changing it. The reason that I don't want to do it this way is that I would like to somehow be able to change the size of multiple objects on the front panel. For example I would like to be able to select the multiple front panel objects and programatically reduce all of their sizes by 80%.
How would I go about doing this?
Thanks very much,
CalTech
(3,628 Views)
Here's one way to do it.
The code is in LV 7.1
/Thomas
"CalTech" skrev i meddelandet
news:50650000000800000092DE0000-1079395200000@exchange.ni.com...
> Thanks very much,
> CalTech
[Attachment Resize_Controls.vi, see below]
(3,626 Views)
Would you be able to translate the 7.1 code into 6.1? I am working on getting a 7.0 student edition but I was informed, (about 2 weeks ago), that there is not a student version of 7.1 So if you could for the time bieng 6.1 I could use.
CalTech
(3,626 Views)
I have older versions of LV handy so I went ahead and saved ThomasG's code to 6.1 for you.
Ryan K.
(3,626 Views)
