Programatically changing y-axis label
Hello All,
In a X-Y plot how does one change the y-axis label programatically? I have the y-axis set up to show counts/sampling time and the sampling time is user controlled. So I would like the y-axis label to show "counts/5 sec" or something like that. I cannot see any option in the property node that shows Y-axis label.
Does anyone have any ideas about I do this? Thanks.
KB
(3,681 Views)
Here is an example of what I think you want to do.
Here is how you do it. Go to the block diagram and right click on the graph/ select create then property node/ then once the property node is on the block diagram then you will left click on it and then select yscale/name label/text then you wire a control to the property node. I hope this is the info you are looking for.
Joe
Joe.
"NOTHING IS EVER EASY"
(3,681 Views)
Thank you, Joe. That worked.
(3,681 Views)
The graph property would be Y Scale>>NameLabel. You can change all
sorts of things there including the Text property.
Greg McKaskle
(3,681 Views)
