Programatically toggle tip strips display (on/off) on remote panel
i'm trying to find a way to programatically toggle the tips strips display (on /off) on a remote panel. This remote panel server runs on a cRIO target. On a Windows application, the application property "Show FP Tip Strips Property" works well. On the remote panel, it returns no error but doesn't change anything...Thanks for any idea !
Vincent
Vincent
(3,265 Views)
You can't set front panel properties on crio code because code on that platform don't have front panels. Remote front panels are for development use and should not be used as part of a deployed system.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,216 Views)
