Programitically deploy a Real-Time source distribution.
I want to programitically deploy a Real-Time source distribution from my host VI.  I assume I need to FTP the build but I am not sure what file or files from the build need to be sent.
(2,913 Views)
The Replication and Deployment (RAD) Utility is a tool that does that.  If you want to include it in your own code, then you can use it as an reference example.  http://zone.ni.com/devzone/cda/epd/p/id/5986
Also, there is a get set example that shipped with LabVIEW 2012.  You can find that using the Example Finder from the help menu of LabVIEW.  Just search for "RT".
Wire Warrior
Behold the power of LabVIEW as my army of Roomba minions streaks across the floor!
(2,905 Views)
