Programmable input filters 9435
Is the NI 9435 capable of a programmable input filter?
Dan Shangraw, P.E.
(3,312 Views)
This is the code I want to use on the 9435
http://zone.ni.com/devzone/cda/tut/p/id/4287#toc0
Is this posible.  I don't have a digital filter option in my MAX API when I try to do this.  If the 9435 isn't cabable of doing this is there another technique that would acomplish the same thing?
Dan Shangraw, P.E.
(3,295 Views)
I have solved it in software using the timout event
I have the change detection digital read in an event loop.  I store the digital data in a shift register in the event loop, and set the timout value to my filter time.
When a change is detected I set the timeout case in the event loop to my filter time.
If I don't see a change event my timeout event fires and sends the digital data stored in the shift register to my consumer loop.  After the timeout event fires I set the timout to -1.  A timout value is only trigged when I get a digital change event.
This seems to work well.
Hopefully NI will add programatic filtering on the 9435 Smiley Wink  That is my wish
Dan Shangraw, P.E.
(3,287 Views)
Hello ASTDan,
Glad to hear that the software solution you found worked for you! I know that the 65XX series have programmable filters but not on the 94X series for C-series. It does have an AC smoothing filter as indicated on the page 13 of the manual but its not programmable. I would like to say that we are always looking for ways to improve our products and if you follow the link below you can make a product suggestion of your own!
Product Suggestion Center
Let us know if you have any other questions or concerns!
Cheers!
Corby_B
http://www.ni.com/support
(3,270 Views)
