Programmable power supply
Hi cbutcher,
I have created a VI for testing my power supply as you suggested, it works, huge thanks to everybody for suggestions, now just for one thing I need help, I want to read output voltage continuously and at the same time want to adjust output voltage. As I understand I have to put READ function inside of while loop with shift register for continuous read, but can write and read function work simultaneously? Here is the VI I have created just for voltage write command
Message 11 of 11
(973 Views)
