Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Programmatic call of shared variables.
B.Settles
Member
11-14-2006
06:54 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
At run time, can you programmatically decide which shared variable to read or write to?
"All truths are easy to understand once they are discovered; the point is to discover them." -- Galileo Galilei
0
Kudos
Message
1
of 2
(2,528 Views)
Reply
Re: Programmatic call of shared variables.
Xaq
NI Employee (retired)
11-15-2006
01:29 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You can programmatically change the URL a shared variable is bound to. Check out
this knowledgebase
article for an example.
0
Kudos
Message
2
of 2
(2,503 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
